Enable Square-SMLT Globally
Use square-Split MultiLink Trunking (SMLT) to form an SMLT aggregation group. In a square configuration, enable square-SMLT globally on each of the four switches.
Important
Important
The following command also activates full-mesh configurations.
This procedure is supported only on a DvR Controller. It is not supported on a DvR Leaf node.
    enable
    configure terminal
  2. Enable square-SMLT:
    multicast smlt-square
